Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: my new {old mk1}
    Jul 2009
    WA
    my new {old mk1}
    Hi i just picked up the mk1 i brought off carsales today havnt had time to get pics up yet but will tomorrow after a good clean.I am searching little advice on some rims that i picked up yesterday they are bbs 14 x 7 R's i think but the offset is 40 will they be ok to put on with a drop of 1"1/2.cheers
    1988 corrado G60 LHD dark green, full miltek , borbet e's .k w coilovers
    2006 T5 tdi semi auto
    1977 mk1 gls 2 door,1.8 on twin 45 dellorto's
    2002 bora 4 motion,kw coilovers,x force full stainless,r32 rims
    Aug 2009
    Wheels should fit even with ballooning tires with a high offset like that.
    Keen for pics.
    Jul 2009
    WA
    cheers for the advice, i really wanted some 40 or 45 profiles is this possible?i am new to all this offset m'larky
    Aug 2009
    I'm certainly no expert, sir, but I'd imagine even 195's wouldn't scrub at all. 1 1/2" of drop is not a lot. You should be well in the clear, i'd imagine.
    Happy to be corrected though!
    Jul 2009
    WA
    thanks again,just been exploring on vortex so have sort of a good idea of offsets now lol.will go as low as possible or as low as the fuzz will let me
    Jun 2007
    Eastern Suburbs Melbourne
    if you want to go really low (most probably on coilovers) you'll have to space those wheels out about 10mm (min) to clear the strut.
    I'd also look at running a smaller size/profile tyre, to avoid scrubbing issues when you're really low.
    If you're only going to drop it 1.5 inches (most probably on springs) they should clear fine, although I'd recommend a 185/60/14 to again minimise chances of rubbing on 'softer/worn/older' suspension. 195's might give you slight issues.
    HTH.
    i like volkswagens
    Jul 2009
    WA
    low sounds good so coilovers it is then,cheers
    Jul 2009
    WA
    pics today
    some of you already now this car,i brought it from VIC recently and will be restoring and modding over the coming years so will be picking your brains for help in the coming months as i am a plasterer not a mechanic.ok some pics taken today,enjoy
    Aug 2009
    Looks very straight! Can't need too much of a resto!
    Hope you have fun with it.
    Jul 2009
    WA
    will take pics of the bad bits later,needs rego but i hope should go thro ok as it has road worthy ticket from VIC
